[mapguide-trac] #397: Symbolization: Overline is too close to text
MapGuide Open Source trac_mapguide at osgeo.org
Sun Jan 13 12:41:31 EST 2008
 Reporter:  louisewatson       |         Owner:  louisewatson
     Type:  defect             |        Status:  closed
 Priority:  medium             |     Milestone:  2.0
Component:  Rendering Service  |       Version:  2.0.0
 Severity:  major              |    Resolution:  fixed
 Keywords:                     |   External_id:  0107175
Changes (by louisewatson):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 The underline position is used to place the overline.  However, the
 underline position is stored as a negative value.  In the case of
 overline, this position was added to the cap height - incorrect given that
 underline position is negative.  The fix was to subtract the position
 rather than add it.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/397#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
