[mapguide-trac] #413: Feature Joins totally broken
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jan 28 23:11:26 EST 2008
 Reporter:  jng           |         Owner:
     Type:  defect        |        Status:  new
 Priority:  high          |     Milestone:  2.0
Component:  General       |       Version:  2.0.0
 Severity:  blocker       |    Resolution:
 Keywords:  feature join  |   External_id:
Comment (by jng):
 Steps to reproduce.
 In MapGuide Studio 2008 (MGOS 1.2.0)
 1. Load Parcels.shp from the MapGuide Studio sample data via load
 procedure. Create both feature source and layer.
 2. Create an ODBC connection to parcels.mdb in the sample data. Upload the
 database as part of the resource data.
 3. Create a feature join between the Parcels (shp) and the Parcels (mdb)
 on the "ID" property. I used "Joined" as the name prefix.
 4. Create a layer from the Parcels(shp) feature source. Use the extended
 feature class. Create a polygon theme on the property "Joined_RTYPE".
 5. Preview the layer, and the joined parcels are rendered correctly.
 In MapGuide Studio 2009 beta. (MGOS 2.0.0 RC1)
 Repeat the above steps. The joined parcels will not render when you reach
 the 5th step.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/413#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
