[mapguide-trac] #409: Rendering: black background with FORMAT!=PNG inside ajaxmappane.templ
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jan 29 03:11:12 EST 2008
 Reporter:  ulysess                         |         Owner:
     Type:  defect                          |        Status:  new
 Priority:  medium                          |     Milestone:  2.0
Component:  Rendering Service               |       Version:  2.0.0
 Severity:  major                           |    Resolution:
 Keywords:  rendering, ajaxmappane, format  |   External_id:
Comment (by ulysess):
 Replying to [comment:1 tomfukushima]:
 > Can someone check to see if this happens in MGOS 1.2 as well? Thanks,
 Tom
 Tested. This doesn't happens with the MGOS 1.2.
 Sometimes when I use the zoom in/out, show a black background while is
 loading, but finally show the map (1.2)
 I use WinXP+IIS+PHP with default installation on both cases (1.2 and 2.0).
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/409#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
