[mapguide-trac] #623: Fusion Error When Selecting From Search Results
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jul 9 18:40:21 EDT 2008
 Reporter:  poulet1212  |         Owner:
     Type:  defect      |        Status:  closed
 Priority:  medium      |     Milestone:
Component:  Fusion      |       Version:  2.0.1
 Severity:  blocker     |    Resolution:  fixed
 Keywords:              |   External_id:
Changes (by poulet1212):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I Found the problem:
 '''the featureset contained in "selection" parameter is javascript-escaped
 twice.'''
 Looking to the sample above and doing an javascript "unescape" return
 this:
 ''%3C%3Fxml%20version%3D%221.0%22%20encoding%3D%22UTF-8%22%3F%3E%3CFeatureSet%20xmlns%3Axsi%3D%22http%3A%2F%2Fwww.w3.org%2F2001%
 2FXMLSchema-
 instance%22%20xsi%3AnoNamespaceSchemaLocation%3D%22FeatureSet-1.0.0.xsd%22%3E%20%3CLayer%20id%3D%
 223cd8a1cc-0000-1000-8002-
 001560c2f391%22%3E%20%20%3CClass%20id%3D%22Default%3APARC%22%3E%20%20%20%3CID%3E1gEAAA%3D%3D%3C%2FID%3E%20%20%3C%2FClass%3E%20%3C%2FLayer%3E%3C%2FFeatureSet%3E
 Doing once again an unsecape would return this:
 <?xml version="1.0" encoding="UTF-8"?><FeatureSet
 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
 xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer id="3cd8a1cc-
 0000-1000-8002-001560c2f391">  <Class id="Default:PARC">
 <ID>1gEAAA==</ID>  </Class> </Layer></FeatureSet>
 Hacking the params with firebug make the widget work.
 We must figure out where it was escaped twice to solve the problem.
 Rémy
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/623#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
