[mapguide-trac] #318: Stream IO exception : "TCP/IP protocol is mismatched between the Server and Web Extensions"
MapGuide Open Source trac_mapguide at osgeo.org
Sat Jul 12 04:03:49 EDT 2008
Web Extensions"
 Reporter:  fvanderbiest      |         Owner:
     Type:  defect            |        Status:  reopened
 Priority:  medium            |     Milestone:
Component:  General           |       Version:  2.0.1
 Severity:  major             |    Resolution:
 Keywords:  exception TCP/IP  |   External_id:
Changes (by zspitzer):
  * version:  2.0.0 => 2.0.1
Comment:
 I just had a server crash with this on linux using 2.0.1
 <2008-07-13T16:56:02>
  Error: A stream IO exception occurred.
         The TCP/IP protocol is mismatched between the Server and Web
 Extensions.  Please install the same version of Server and Web Extensions.
  StackTrace:
   - MgOperationThread.ProcessMessage line 276 file OperationThread.cpp
   - MgStreamParser.ParseStreamHeader line 91 file System/StreamParser.cpp
 The TCP/IP protocol is mismatched between the Server and Web Extensions.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/318#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
