[mapguide-trac] #630: Fusion search widget bug: solution proposed
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jul 14 16:47:15 EDT 2008
   Reporter:  poulet1212  |       Owner:
       Type:  defect      |      Status:  new
   Priority:  high        |   Milestone:
  Component:  Fusion      |     Version:  2.0.1
   Severity:  critical    |    Keywords:
External_id:              |
 Hi all,
 already described the problem here:
 http://trac.osgeo.org/mapguide/ticket/623
 I found a fix that worked.
 First, looking at widgets/Search/Search.templ:
 function CellClicked(sel)
     var map = GetParent().Fusion.getMapByName(mapName);
     map.setSelection(sel, false, true);
 Should be changed like this to match correctly the API:
     map.setSelection(sel, true);
 Second, the call to setSelection from map object is (lib/Map.js):
 setSelection: function(selText, requery, zoomTo) {
          for (var i=0; i<this.aMaps.length; i++ ) {
              this.aMaps[i].setSelection(selText, requery, zoomTo);
 setSelection: function(selText, zoomTo) {
              this.aMaps[i].setSelection(selText, zoomTo);
 Finally, setSelection from Mapguide.js has for params:
 'selection': encodeURIComponent(selText),
 it's proposed to change like this:
 'selection': selText,
 encodeURIComponent encodes twice the params and that make the call-back
 error happend.
 We see that setSelection has finally in Mapguide.js only 2 parameters:
 selText, zoomTo.
 But in Map.js and Search.templ it was called with 3 parameters: selText,
 requery, zoomTo
 Quite confusing for a mistake.
 Rémy
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/630>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
