[mapguide-trac] #645: Problem with mapguide-2.0.1.2716.tar
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jul 30 14:03:49 EDT 2008
 Reporter:  ssnc     |         Owner:
     Type:  defect   |        Status:  new
 Priority:  high     |     Milestone:
Component:  General  |       Version:  2.0.1
 Severity:  blocker  |    Resolution:
 Keywords:           |   External_id:  ssnc
Comment (by tomfukushima):
 I tried opening the file using WinZip 9 and saw the same problem that you
 did.  However, on Linux the file is fine.  Perhaps this is a WinZip
 problem, can you try using tar and gzip on Windows and see if the same
 problems happen?  Or do you know of any reason on why WinZip would fail?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/645#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
