[mapguide-trac] #586: Maestro: Tab enhancements for closing resources
MapGuide Open Source trac_mapguide at osgeo.org
Sun Jun 1 12:20:12 EDT 2008
 Reporter:  jbirch       |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  assigned
 Priority:  low          |     Milestone:
Component:  Maestro      |       Version:
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Comment (by ksgeograf):
 Well, that is not supported in .Net, and apparently there is no easy way
 to fix it.
 I have found this acceptable solution:
 http://www.codeproject.com/KB/cpp/MDITabControl.aspx?msg=1973375
 But it does not use the machine theme, and seems a bit "over the top". I
 am not sure it will work in Mono either.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/586#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
