[mapguide-trac] #593: Incorrect selection behaviour when disabling properties pane
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jun 5 08:46:10 EDT 2008
   Reporter:  isca         |       Owner:
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:
  Component:  AJAX Viewer  |     Version:  2.0.1
   Severity:  major        |    Keywords:  AJAX, properties pane, selection
External_id:               |
 When disabling the properties pane in the AJAX viewer in MapGuide Studio,
 selecting features behaves incorrectly.
 '''To reproduce:'''
 - Create a weblayout with properties pane disabled[[BR]]
 - Select point or linefeature (most visible on high zoom level)
 '''Result:'''
 - Incorrect feature is selected
 It seems to be the map is shifted against the real coordinates.
 The problem is also visible when trying to select a polygon near its
 boundaries. A polygon in the neighbourhood will be selected.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/593>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
