[mapguide-trac] #595: Maestro crashes when editing a layer style
MapGuide Open Source trac_mapguide at osgeo.org
Sat Jun 7 11:55:41 EDT 2008
   Reporter:  andrewd   |       Owner:  ksgeograf
       Type:  defect    |      Status:  new
   Priority:  high      |   Milestone:
  Component:  Maestro   |     Version:  2.0.1
   Severity:  critical  |    Keywords:
External_id:            |
 Make a new layer. Connect it to a point data source (in my case from a
 shape file - managed). Make a new style rule. Change the size units to
 Meters (I usually also change the Size Context to "Map units" as
 well)....and you'll get a crash. I've tried this on 2 different computers
 now. I get the following:
 See the end of this message for details on invoking
 just-in-time (JIT) debugging instead of this dialog box.
 ************** Exception Text **************
 System.ArgumentException: Requested value 'MappingUnits' was not found.
    at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase)
    at
 OSGeo.MapGuide.Maestro.ResourceEditors.GeometryStyleEditors.PointFeatureStyleEditor.SizeUnits_SelectedIndexChanged(Object
 sender, EventArgs e)
    at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
    at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m)
    at System.Windows.Forms.ComboBox.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message&
 m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
 IntPtr wparam, IntPtr lparam)
 ************** Loaded Assemblies **************
 mscorlib
     Assembly Version: 2.0.0.0
     Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
     CodeBase:
 file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
 Maestro
     Assembly Version: 1.0.7.40948
     Win32 Version: 1.0.7.40948
     CodeBase:
 file:///C:/Program%20Files/HexaD/MapGuide%20Maestro/Maestro.exe
     CodeBase:
 file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
 System
     CodeBase:
 file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
 System.Drawing
     CodeBase:
 file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
 Globalizator
     Assembly Version: 1.0.7.0
     Win32 Version: 1.0.7.0
     CodeBase:
 file:///C:/Program%20Files/HexaD/MapGuide%20Maestro/Globalizator.DLL
 System.Xml
     CodeBase:
 file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
 OSGeo.MapGuide.MaestroAPI
     Assembly Version: 1.0.7.40946
     Win32 Version: 1.0.7.40946
     CodeBase:
 file:///C:/Program%20Files/HexaD/MapGuide%20Maestro/OSGeo.MapGuide.MaestroAPI.DLL
 OSGeo.MapGuide.Maestro.MaestroEditorInterface
     CodeBase:
 file:///C:/Program%20Files/HexaD/MapGuide%20Maestro/OSGeo.MapGuide.Maestro.MaestroEditorInterface.DLL
 System.Web
     CodeBase:
 file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
 System.Configuration
     CodeBase:
 file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
 ykgfc4rm
     CodeBase:
 ea37kmc7
     CodeBase:
 haihl4xj
     CodeBase:
     Assembly Version: 1.0.7.40947
     Win32 Version: 1.0.7.40947
     CodeBase:
 file:///C:/Program%20Files/HexaD/MapGuide%20Maestro/OSGeo.MapGuide.Maestro.ResourceEditors.DLL
 OSGeo.MapGuide.Maestro.FusionEditor
     CodeBase:
 file:///C:/Program%20Files/HexaD/MapGuide%20Maestro/OSGeo.MapGuide.Maestro.FusionEditor.DLL
 okjqzqrx
     CodeBase:
 e4iegszn
     CodeBase:
 System.Data
     CodeBase:
 file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
 Topology
     Assembly Version: 1.0.8.24721
     Win32 Version: 1.0.8.24721
     CodeBase:
 file:///C:/Program%20Files/HexaD/MapGuide%20Maestro/Topology.DLL
 wudxpikb
     CodeBase:
 hywfi3sy
     CodeBase:
 ************** JIT Debugging **************
 To enable just-in-time (JIT) debugging, the .config file for this
 application or computer (machine.config) must have the
 jitDebugging value set in the system.windows.forms section.
 The application must also be compiled with debugging
 enabled.
 For example:
 <configuration>
     <system.windows.forms jitDebugging="true" />
 </configuration>
 When JIT debugging is enabled, any unhandled exception
 will be sent to the JIT debugger registered on the computer
 rather than be handled by this dialog box.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/595>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
