[mapguide-trac] #601: MapGuide Maestro: image tiling in composite mode is not working
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jun 13 04:05:11 EDT 2008
 Reporter:  dumas65  |         Owner:  ksgeograf
     Type:  defect   |        Status:  new
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:  2.0.1
 Severity:  trivial  |    Resolution:
 Keywords:           |   External_id:
Comment (by ksgeograf):
 From the config file, it seems that GDal does not like your files.
 If you create a new data source, use "single file" mode, and add just one
 of the files what happens when you press the "refresh" button in the
 coordinate system override box?
 I would expect that it is reporting a "default" coordinate systems, which
 is an indication that it does not work.
 If it displays the correct coordinate system, try adding the file as the
 only file in composite mode, and then click "refresh" in the coordinate
 system override box.
 Let me know what happens.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/601#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
