[mapguide-trac] #592: Layer preview
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jun 13 15:15:28 EDT 2008
#592: Layer preview
 Reporter:  andrewd      |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  closed
 Priority:  medium       |     Milestone:
Component:  Maestro      |       Version:
 Severity:  minor        |    Resolution:  fixed
 Keywords:               |   External_id:
Changes (by ksgeograf):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 I have now added a preferences dialog. You can choose browser and viewer
 type there. When the installer is built for the next version, it will
 place two files "Preview layout.WebLayout" and "Preview
 layout.ApplicationDefinition". The user can then replace those with a
 custom version. If they are not present, Maestro will use an internal
 version.
 If you are eager to replace the built in version with your own before the
 installer is complete, you can copy one in, and name it as above.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/592#comment:10>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
