[mapguide-trac] #592: Layer preview
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jun 13 15:55:16 EDT 2008
#592: Layer preview
 Reporter:  andrewd      |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  reopened
 Priority:  medium       |     Milestone:
Component:  Maestro      |       Version:
 Severity:  minor        |    Resolution:
 Keywords:               |   External_id:
Changes (by andrewd):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Thanks so much for adding that preview link!! For a project like this,
 having access to the latest builds is pretty important. Now, I've just
 tried out the preview for a few layers - here's what happens:
 data connections -> these work fine.
 layers -> fusion previews don't work. I always get an error (no matter
 what layer I try): "Failed while creating map preview: There is an error
 in XML document (2,2)."
 The Regular method works in some cases, but not all. One problem is
 definitely scale ranges. If I preview a layer that's got scale ranges, it
 needs to either ignore those ranges in the preview, or else start the
 preview at the first scale. If I zoom out far enough, my layer does appear
 in the legend - but isn't anywhere to be found in the map area. The
 preview should really try to zoom to the extents of the layer.
 My raster layers are working - though they have the same scale range
 problem...
 I have a point layer that reads it's data from a database (DSN) - this
 layer doesn't work. It's got no special scale ranges - so I'm not sure why
 it doesn't show up in the preview...
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/592#comment:12>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
