[mapguide-trac] #608: Occasional MgPremissionDeniedException
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jun 18 15:45:04 EDT 2008
 Reporter:  andrewd  |         Owner:  ksgeograf
     Type:  defect   |        Status:  assigned
 Priority:  high     |     Milestone:
Component:  Maestro  |       Version:
 Severity:  major    |    Resolution:
 Keywords:           |   External_id:
Comment (by andrewd):
 Ok - update....I was just logged into my site (the actual website) in my
 browser. I logged in as the user that only has read rights (since I'm
 testing this site out, I'm logging in as though my end user would). Then I
 wanted to make a change to something, so I opened up Maestro, and logged
 in as Administrator. Once it logged in, my folder looked empty. I had to
 do a refresh to get the items to show up. Then I tried opening one of them
 - no luck. Permission Denied. I believe this is exactly the same thing
 that happened before (same order of things). It seems as though Maestro is
 for some reason seeing that I've already got a session open, and trying to
 use that instead (rather than actually logging in using the credentials I
 give it).
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/608#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
