[mapguide-trac] #378: AJAX viewer does not load map in Firefox 3 RC 1
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jun 20 13:21:30 EDT 2008
 Reporter:  jng          |         Owner:
     Type:  defect       |        Status:  new
 Priority:  high         |     Milestone:  2.1
Component:  AJAX Viewer  |       Version:  2.0.1
 Severity:  major        |    Resolution:
 Keywords:               |   External_id:  1085043
Comment (by tomfukushima):
 OK, it looks like we're not getting much progress on this. I compiled the
 code and debugged and sure enough it looks like FF3 is sending the content
 type in the extended format that Zac mentions.  And sure enough the code
 expects it in the FF2 format and that is causing the failures.  Can you
 try using the attached files (!FixedFiles.zip, MD5:
 1339dedef68a59cc2646c4caa6ee0663) to see if it fixes your problems and
 doesn't introduce new ones?
 This will only work for MGOS 2.0.1 on Windows.
 To do this: Stop your web server. Find occurrences of the file in your
 webserverextensions install and replace them with the attached (you should
 really also make copies of the originals in case you need to restore
 things).  Restart your web server. Test.
 If you test this please post a note in this ticket with the configuration
 you tested and the results.
 I'll post a patch (called FF3Fix.path or something like that) for those
 who are compiling from source.
 Thanks, Tom.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/378#comment:18>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
