[mapguide-trac] #611: Layer referencing group that does not exist in MgMap causes server error
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jun 23 16:59:02 EDT 2008
   Reporter:  dmaidlow  |       Owner:
       Type:  defect    |      Status:  new
   Priority:  low       |   Milestone:
  Component:  General   |     Version:  2.0.0
   Severity:  trivial   |    Keywords:
External_id:            |
 Open a runtime Map object using the API (I was using .NET)[[BR]]
 Create an MgLayerGroup - do not add it to the MgMap object[[BR]]
 Create an MGLayer pointing to an existing library layer[[BR]]
 Set the layer to be in the newly created group[[BR]]
 Add the layer to the mgMap object[[BR]]
 save the MgMap[[BR]]
 Server and Web tier should crash on save.[[BR]]
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/611>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
