[mapguide-trac] #601: MapGuide Maestro: image tiling in composite mode is not working
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jun 25 09:35:18 EDT 2008
 Reporter:  dumas65  |         Owner:  ksgeograf
     Type:  defect   |        Status:  assigned
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:
 Severity:  trivial  |    Resolution:
 Keywords:           |   External_id:
Comment (by ksgeograf):
 Ok, I just tried again.
 I have one single file (from this post):
 C:\ecw2\7722.ecw
 I have an Alias for C:, named CDrev.
 I have created four different featuresources:
 1. Single file or folder, path: C:\ecw2\7722.ecw
 2. Single file or folder, path: %MG_DATA_PATH_ALIAS[CDrev]%ecw2/
 3. Composite, add folder, selected [CDrev]ecw2
 4. Composite, add file, selected C:\ecw2\7722.ecw
 For each of these, I have create a layer.
 I then insert all four layers into a map.
 Then I click on "Set view to current layers extent".
 For all four layers, I get the exact same result: the correct coordinates.
 Does your setup differ in any noticeable way?
 Can you reproduce my results?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/601#comment:15>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
