[mapguide-trac] #609: Layer previews not zooming to extents
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jun 25 16:23:09 EDT 2008
 Reporter:  andrewd  |         Owner:  ksgeograf
     Type:  defect   |        Status:  assigned
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:
 Severity:  minor    |    Resolution:
 Keywords:           |   External_id:
Comment (by ksgeograf):
 When you press "Refresh" Maestro actually reads it from the datasource, so
 it may not be there. But that may be the problem, if the featuresource has
 a coordinate system override, the spatial context is not returned.
 Does that match your observations?
 If so, I will look for an alternative way of reading the spatial context.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/609#comment:12>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
