[mapguide-trac] #612: Opera 9.50 doesn't load map using the Basic Viewer
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jun 25 17:29:21 EDT 2008
 Reporter:  zspitzer     |         Owner:
     Type:  defect       |        Status:  new
 Priority:  medium       |     Milestone:
Component:  AJAX Viewer  |       Version:  2.0.1
 Severity:  critical     |    Resolution:
 Keywords:               |   External_id:
Comment (by tomfukushima):
 I'd love to see this working because then I might be able to browse to
 !MapGuide sites on my WII! :)
 I searched for the string GETVISIBLEMAPEXTENT and found it in
 !WebServerExtensions/www/viewerfiles/ajaxmappane.templ in the !RequestMap
 function.  If you're up for it, try putting some alert statements in there
 and see where the script is failing.  If I have it right, !RequestMap
 (which does GETVISIBLEMAPEXTENT)calls !OnMapRequested which then calls
 !RequestMapImage (which does the missing GETDYNAMICOVERLAYIMAGE
 operation).  So somewhere in there, things are failing in Opera.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/612#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
