[mapguide-trac] #613: Image format parameter is not being properly handled when specified in lowercase
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jun 26 15:13:51 EDT 2008
lowercase
   Reporter:  brucedechant       |       Owner:
       Type:  defect             |      Status:  new
   Priority:  low                |   Milestone:  2.1
  Component:  Rendering Service  |     Version:  2.0.1
   Severity:  minor              |    Keywords:
External_id:                     |
 The image format parameter used by several rendering service operations is
 not being properly handled when it is in lowercase because both AGG and GD
 expect it to be in uppercase when they use it internally for processing
 the requested image format.
 The solution is to convert the incoming image format parameter to
 uppercase right before the AGG or GD processing begins.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/613>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
