[mapguide-trac] #454: RC4 login.php Administrator Fails
MapGuide Open Source trac_mapguide at osgeo.org
Mon Mar 3 11:22:34 EST 2008
 Reporter:  crispinatime  |         Owner:
     Type:  defect        |        Status:  new
 Priority:  medium        |     Milestone:  2.1
Component:  Map Admin     |       Version:  2.0.0
 Severity:  major         |    Resolution:
 Keywords:                |   External_id:
Comment (by tomfukushima):
 Hi Crispin, This is probably not an XP issue. Most of the developers use
 XP here and do not have problems with it.  I was able to produce a problem
 for a while on Win2003 but it went away and I wasn't able to get it to
 show up again.  Could you try moving the "C:\Program
 Files\!MapGuideOpenSource2.0\!WebServerExtensions\Php" as the first entry
 in your path an see if that makes any differrence?
 Also, if you have some firewalls or antivirus programs, please try
 disabling them to see if it makes any difference.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/454#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
