[mapguide-trac] #477: Apache mapguide.conf for Linux Problems
MapGuide Open Source trac_mapguide at osgeo.org
Mon Mar 3 23:11:13 EST 2008
 Reporter:  amorsell   |         Owner:
     Type:  defect     |        Status:  new
 Priority:  medium     |     Milestone:  2.1
Component:  Map Agent  |       Version:  2.0.0
 Severity:  major      |    Resolution:
 Keywords:             |   External_id:
Old description:
> They following two lines in
> /usr/local/mapguideopensource/webserverextensions/apache/conf/mapguide.conf
> (referenced by httpd.conf)
> Are commented by default but are necessary in order for the mapagent to
> be functional.
> Currently reads:
> #LoadModule mgmapagent_module modules/mod_mgmapagent.so
> #AddHandler mgmapagent_handler fcgi
> Should be:
New description:
 Are commented by default but are necessary in order for the mapagent to be
 functional.
 Currently reads:
 Should be:
Comment (by jbirch):
 Re-formatted the description using WikiFormatting.  Basically you can
 enclose text that needs to be pre-formatted with three curly-braces.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/477#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
