[mapguide-trac] #478: Task Pane home page does not receive MAPNAME request parameter on first load.
MapGuide Open Source trac_mapguide at osgeo.org
Tue Mar 4 01:09:57 EST 2008
load.
   Reporter:  jng          |       Owner:
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:  2.1
  Component:  AJAX Viewer  |     Version:  2.0.0
   Severity:  major        |    Keywords:
External_id:               |
 If you load the AJAX viewer with an initial task page defined, that task
 page won't receive the MAPNAME parameter on the first load.
 However going back to the initial task url via the home button on the task
 pane, it will then have the MAPNAME parameter.
 The initial task url should receive the same set of request parameters on
 first load as it does when you go back to it via the home button on the
 task pane.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/478>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
