[mapguide-trac] #454: MapGuide 2.0 - login.php Administrator Fails
MapGuide Open Source trac_mapguide at osgeo.org
Fri Mar 7 14:37:51 EST 2008
 Reporter:  crispinatime  |         Owner:  ronnielouie
     Type:  defect        |        Status:  new
 Priority:  medium        |     Milestone:  2.1
Component:  Map Admin     |       Version:  2.0.0
 Severity:  major         |    Resolution:
 Keywords:                |   External_id:
Comment (by ronnielouie):
 Crispin,
 Can you edit your php.ini file to enable the following, restart IIS, and
 try the admin page again to see if it will report anything?  Thanks.
 display_errors = On
 display_startup_errors = On
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/454#comment:11>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
