[mapguide-trac] #473: Fusion: Selection Panel not working in "Learn" template
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 13 19:17:20 EDT 2008
 Reporter:  jng      |         Owner:
     Type:  defect   |        Status:  new
 Priority:  medium   |     Milestone:
Component:  Samples  |       Version:  2.0.0
 Severity:  major    |    Resolution:
 Keywords:           |   External_id:
Comment (by brucedechant):
 Do the other templates work for you (Aqua, Slate, etc...)?
 This might indicate an issue with the template if the other ones are
 working with the exact same dataset.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/473#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
