[mapguide-trac] #500: Schema Cache performance enhancements
MapGuide Open Source trac_mapguide at osgeo.org
Fri Mar 14 09:43:52 EDT 2008
 Reporter:  brentrobinson              |         Owner:  brucedechant
     Type:  enhancement                |        Status:  closed
 Priority:  medium                     |     Milestone:
Component:  Feature Service            |       Version:
 Severity:  major                      |    Resolution:  fixed
 Keywords:  Performance Studio Viewer  |   External_id:
Changes (by brentrobinson):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 The DescribeSchemaAsXml changes make the following time difference for the
 scenario:
     - Create a feature source on an Oracle datastore with 400 tables and
 about 6000
       columns
     - Create a layer that references this feature source.
     - Execute the following on the Oracle instance:
         alter system flush buffer_cache
     - restart MG server
     - Go into Studio and open the layer.
 The following shows the times (in seconds) from when the layer open is
 started until the layer's dropdowns are populated (before and after the
 fix):
                                                         Before
 After
         Total                                           25              14
         FeatureService.DescribeSchemaAsXml part         16               7
 For the GetClassIdentityProperties changes,  the scenario checked was:
     - Create a feature source on an Oracle datastore with 1500 tables and
     - Create 50 layers each for a different class from the above feature
 source
     - Create a map definition that includes all 50 layers
     - create a web layout on the map definition
     - restart MG server
     - Open the web layout on the DWF viewer
     - do a second run, opening the web layout.
 The time from when the login prompt was exited, until the legend showed up
 was taken. The following shows the times in seconds:
                         Before          After
         Run1            17              12
         Run2            11               2
 Timings were done with Studio and MG Server on a Windows XP machine ( 2.66
 GHz, 2 CPU, 3Gb RAM), accessing Oracle over a LAN. Timings may vary in
 other environments.
 Revision: 3090
 Author: brucedechant
 Date: 5:58:47 PM, Thursday, March 13, 2008
 Message:
 Fix for trac ticket 500 - Schema Cache performance enhancements
 http://trac.osgeo.org/mapguide/ticket/500
 - Submitted on behalf of Brent Robinson
 Modified : /trunk/MgDev/Server/src/Common/Cache/FeatureServiceCache.cpp
 Modified : /trunk/MgDev/Server/src/Common/Cache/FeatureServiceCache.h
 Modified :
 /trunk/MgDev/Server/src/Common/Cache/FeatureServiceCacheEntry.cpp
 Modified : /trunk/MgDev/Server/src/Common/Cache/FeatureServiceCacheEntry.h
 Modified : /trunk/MgDev/Server/src/Common/Cache/Makefile.am
 Modified : /trunk/MgDev/Server/src/Common/Cache/ServerCache.vcproj
 Modified :
 /trunk/MgDev/Server/src/Services/Feature/ServerDescribeSchema.cpp
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/500#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
