[mapguide-trac] #506: Mapguide 2.0 Apache won't compile on Ubuntu?
MapGuide Open Source trac_mapguide at osgeo.org
Mon Mar 17 23:54:21 EDT 2008
 Reporter:  Rothgar       |         Owner:
     Type:  defect        |        Status:  new
 Priority:  high          |     Milestone:
Component:  Build System  |       Version:  2.0.0
 Severity:  critical      |    Resolution:
 Keywords:                |   External_id:
Comment (by Rothgar):
 root at mapsrv:/home/mapguide-src/LinuxApt/httpd-2.2.4/srclib/apr# cat
 exports.c | grep Ronnie
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_thread_mutex.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_env.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_poll.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_fnmatch.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_global_mutex.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_pools.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_file_io.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_version.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_mmap.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_dso.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_thread_proc.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_errno.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_shm.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_network_io.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_signal.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_user.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_atomic.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_random.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_thread_cond.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_thread_rwlock.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_getopt.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_strings.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_general.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_proc_mutex.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_tables.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_file_info.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_allocator.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_portable.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_hash.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_time.h
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/include/apr_lib.h
 root at mapsrv:/home/mapguide-src/LinuxApt/httpd-2.2.4/srclib/apr# cat apr-
 config.out | grep Ronnie
 APR_SOURCE_DIR="/home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr"
 APR_BUILD_DIR="/home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr"
 root at mapsrv:/home/mapguide-src/LinuxApt/httpd-2.2.4# cat httpd | grep
 Ronnie2
 relink_command="(cd /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4; {
 test -z \"\${LIBRARY_PATH+set}\" || unset LIBRARY_PATH || { LIBRARY_PATH=;
 export LIBRARY_PATH; }; }; { test -z \"\${COMPILER_PATH+set}\" || unset
 COMPILER_PATH || { COMPILER_PATH=; export COMPILER_PATH; }; }; { test -z
 \"\${GCC_EXEC_PREFIX+set}\" || unset GCC_EXEC_PREFIX || {
 GCC_EXEC_PREFIX=; export GCC_EXEC_PREFIX; }; }; { test -z
 \"\${LD_RUN_PATH+set}\" || unset LD_RUN_PATH || { LD_RUN_PATH=; export
 LD_RUN_PATH; }; };
 PATH=\"/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/bin:/bin:/usr/bin:/usr/X11R6/bin:/home/louier/bin\";
 export PATH; gcc -g -O2 -pthread -o \$progdir/\$file .libs/modules.o
 buildmark.o -Wl,--export-dynamic  server/.libs/libmain.a
 modules/http/.libs/libmod_http.a modules/mappers/.libs/libmod_so.a
 server/mpm/prefork/.libs/libprefork.a os/unix/.libs/libos.a -lm
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/pcre/.libs/libpcre.a
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr-
 util/.libs/libaprutil-1.so /usr/lib/libexpat.so
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/.libs/libapr-1.so
 -luuid -lrt -lcrypt -lpthread -ldl  -Wl,--rpath
 -Wl,/home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr-
 util/.libs -Wl,--rpath
 -Wl,/home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/.libs
 -Wl,--rpath
 -Wl,/usr/local/mapguideopensource/webserverextensions/apache2/lib)"
   notinst_deplibs='
 util/libaprutil-1.la
 /home/louier/mapguide/Ronnie2/LinuxApt/httpd-2.2.4/srclib/apr/libapr-1.la'
 These are just a few of the files?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/506#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
