[mapguide-trac] #506: Mapguide 2.0 Apache won't compile on Ubuntu?
MapGuide Open Source trac_mapguide at osgeo.org
Tue Mar 18 04:50:18 EDT 2008
 Reporter:  Rothgar       |         Owner:
     Type:  defect        |        Status:  new
 Priority:  high          |     Milestone:
Component:  Build System  |       Version:  2.0.0
 Severity:  critical      |    Resolution:
 Keywords:                |   External_id:
Comment (by Rothgar):
 Now building the MapGuide Server fails with a new error, using the SVN:
 make[4]: Entering directory `/home/mapguide-svn/Server/src/Common/Cache'
 if /bin/sh ../../../../libtool --tag=CXX --mode=compile g++
 -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
 -DPACKAGE_VERSION=\"2.0.0\" -DPACKAGE_STRING=\"mapguide\ 2.0.0\"
 -DPACKAGE_BUGREPORT=\"http://mapguide.osgeo.org\" -DPACKAGE=\"mapguide\"
 -DVERSION=\"2.0.0\" -DPACKAGE=\"mapguide\" -DVERSION=\"2.0.0\"
 -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1
 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1
 -DSTDC_HEADERS=1 -DHAVE_UNISTD_H=1 -DHAVE_MATH_H=1 -DHAVE_NETDB_H=1
 -DHAVE_NETINET_IN_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_SOCKET_H=1
 -DHAVE_GETHOSTBYNAME=1 -DHAVE_SOCKET=1 -DHAVE_HTONS=1 -DHAVE_CONNECT=1
 -DHAVE_SHUTDOWN=1 -I. -I. -I../../../../Common/Foundation
 -I../../../../Common/PlatformBase -I../../../../Common/MapGuideCommon
 -I../../../../Common/Geometry -I../../../../Common/MdfModel
 -I../../../../Oem/ACE/ACE_wrappers -I../../../../Oem/FDO/inc    -O2 -g
 -pipe -march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions -MT
 ServerCacheBuild.lo -MD -MP -MF ".deps/ServerCacheBuild.Tpo" -c -o
 ServerCacheBuild.lo ServerCacheBuild.cpp; \
  then mv -f ".deps/ServerCacheBuild.Tpo" ".deps/ServerCacheBuild.Plo";
 else rm -f ".deps/ServerCacheBuild.Tpo"; exit 1; fi
 mkdir .libs
  g++ -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
 -DPACKAGE_VERSION=\"2.0.0\" "-DPACKAGE_STRING=\"mapguide 2.0.0\""
 -I../../../../Oem/ACE/ACE_wrappers -I../../../../Oem/FDO/inc -O2 -g -pipe
 ServerCacheBuild.lo -MD -MP -MF .deps/ServerCacheBuild.Tpo -c
 ServerCacheBuild.cpp  -fPIC -DPIC -o .libs/ServerCacheBuild.o
 `-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.
 In file included from FeatureServiceCache.h:22,
                  from FeatureServiceCache.cpp:19,
                  from ServerCacheBuild.cpp:21:
 FeatureServiceCacheEntry.h:24:17: error: Fdo.h: No such file or directory
 FeatureServiceCacheEntry.h:84: error: ISO C++ forbids declaration of
 'FdoFeatureSchemaCollection' with no type
 FeatureServiceCacheEntry.h:84: error: expected ';' before '*' token
 FeatureServiceCacheEntry.h:85: error: 'FdoFeatureSchemaCollection' has not
 been declared
 FeatureServiceCacheEntry.h:111: error: ISO C++ forbids declaration of
 'FdoPtr' with no type
 FeatureServiceCacheEntry.h:111: error: expected ';' before '<' token
 FeatureServiceCache.h:83: error: 'FdoFeatureSchemaCollection' has not been
 declared
 FeatureServiceCache.h:84: error: ISO C++ forbids declaration of
 FeatureServiceCache.h:84: error: expected ';' before '*' token
 FeatureServiceCache.cpp:680: error: 'FdoFeatureSchemaCollection' has not
 been declared
 FeatureServiceCache.cpp: In member function 'void
 MgFeatureServiceCache::SetFdoFeatureSchemaCollection(MgResourceIdentifier*,
 const std::wstring&, int*)':
 FeatureServiceCache.cpp:688: error: 'FdoPtr' was not declared in this
 scope
 FeatureServiceCache.cpp:688: error: 'FdoFeatureSchemaCollection' was not
 declared in this scope
 FeatureServiceCache.cpp:688: error: 'data' was not declared in this scope
 FeatureServiceCache.cpp:688: error: 'class
 _NoAddRefReleaseOnPtr<MgFeatureServiceCacheEntry>' has no member named
 'GetFdoFeatureSchemaCollection'
 FeatureServiceCache.cpp: At global scope:
 FeatureServiceCache.cpp:706: error: expected constructor, destructor, or
 type conversion before '*' token
 FeatureServiceCacheEntry.cpp: In member function 'void
 MgFeatureServiceCacheEntry::SetFeatureSchemaName(const std::wstring&)':
 FeatureServiceCacheEntry.cpp:73: error: 'FdoFeatureSchemaCollection' was
 FeatureServiceCacheEntry.cpp:73: error: expected primary-expression before
 ')' token
 FeatureServiceCacheEntry.cpp: At global scope:
 FeatureServiceCacheEntry.cpp:172: error: variable or field
 'SetFdoFeatureSchemaCollection' declared void
 FeatureServiceCacheEntry.cpp:172: error: 'int
 MgFeatureServiceCacheEntry::SetFdoFeatureSchemaCollection' is not a static
 member of 'class MgFeatureServiceCacheEntry'
 FeatureServiceCacheEntry.cpp:172: error: 'FdoFeatureSchemaCollection' was
 FeatureServiceCacheEntry.cpp:172: error: 'featureSchemaCollection' was not
 FeatureServiceCacheEntry.cpp:173: error: expected ',' or ';' before '{'
 token
 FeatureServiceCacheEntry.cpp:177: error: expected constructor, destructor,
 or type conversion before '*' token
 make[4]: *** [ServerCacheBuild.lo] Error 1
 make[4]: Leaving directory `/home/mapguide-svn/Server/src/Common/Cache'
 make[3]: *** [all-recursive] Error 1
 make[3]: Leaving directory `/home/mapguide-svn/Server/src/Common'
 make[2]: *** [all-recursive] Error 1
 make[2]: Leaving directory `/home/mapguide-svn/Server/src'
 make[1]: *** [all-recursive] Error 1
 make[1]: Leaving directory `/home/mapguide-svn/Server'
 make: *** [all-recursive] Error 1
 root at mapsrv:/home/mapguide-svn#
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/506#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
