[mapguide-trac] #463: Fusion: Tooltips do not work for any flexible layout with any layer source
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 20 16:32:20 EDT 2008
 Reporter:  amorsell  |         Owner:
     Type:  defect    |        Status:  new
 Priority:  high      |     Milestone:
Component:  Fusion    |       Version:  2.0.0
 Severity:  critical  |    Resolution:
 Keywords:            |   External_id:
Comment (by tomfukushima):
 Hi Andy, are you using the !ApplicationDefinition.xml file (i.e. the one
 on the file system; not the ones in the repository) for your Fusion
 templates?  If so could you try updating to the one that is in trunk and
 see if this fixes your problem.  If you are using Studio to create the
 layout, this works for us, can you create a package to reproduce the
 problem and attach it to this ticket? Thanks, Tom
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/463#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
