[mapguide-trac] #502: Feature Join rendering can be momentarily broken due to incorrect case on secondary attribute
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 20 17:11:39 EDT 2008
secondary attribute
 Reporter:  jng           |         Owner:  brucedechant
     Type:  defect        |        Status:  closed
 Priority:  high          |     Milestone:  2.1
Component:  General       |       Version:  2.0.0
 Severity:  critical      |    Resolution:  wontfix
 Keywords:  feature join  |   External_id:
Changes (by brucedechant):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 This is as expected because the join keys are strings. When strings are
 used as keys they are case sensitive. This is one of the dangers in using
 a non numeric key.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/502#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
