[mapguide-trac] #514: Mapguide Broken on Ubuntu?
MapGuide Open Source trac_mapguide at osgeo.org
Mon Mar 24 21:15:18 EDT 2008
   Reporter:  Rothgar    |       Owner:
       Type:  defect     |      Status:  new
   Priority:  high       |   Milestone:
  Component:  Map Admin  |     Version:  2.0.0
   Severity:  major      |    Keywords:
External_id:             |
 MapGuide was working fine on Ubuntu and then all of a sudden stopped
 working, I rebooted the server to see if it would make any difference and
 we still can't login.
 We tried the web interface which is still operational but the login does
 not work saying the credentials are wrong.
 After checking the server there is no "mgserver" running.
 I ran mgserver in the foreground using "mgserver run" and got this error:
 root at mapsrv:/home/jasonm# /home/mapguide/server/bin/mgserver run
 Running the server interactively as an application instead of as a
 service.
 (3017819840) Configuration file "serverconfig.ini" cannot be found or
 cannot be opened.
 Exception occurred in method MgConfiguration.LoadConfiguration at line 110
 in file System/Configuration.cpp
 (3017819840) Server stopped.
 "Serverconfig.ini" exists here:
 root at mapsrv:/home/jasonm# find / -name "serverconfig.ini"
 /home/mapguide-svn/Server/src/Core/serverconfig.ini
 /home/mapguide-src/mapguide-2.0.0/Server/src/Core/serverconfig.ini
 /home/mapguide/server/bin/serverconfig.ini
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/514>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
