[mapguide-trac] #520: Out of memory. bad allocation Errors using Tiled Map
MapGuide Open Source trac_mapguide at osgeo.org
Wed Mar 26 20:15:43 EDT 2008
   Reporter:  zspitzer      |       Owner:
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:
  Component:  Tile Service  |     Version:  2.0.0
   Severity:  major         |    Keywords:
External_id:                |
 Following some errors like
 Error: Failed to stylize layer: SEAS
         An unclassified exception occurred.
 I then see this error in the log file, following which the server becomes
 unresponsive and the service can't be stopped (using windows 2003 & SDF
 files )
 <2008-03-26T17:21:47>                   Administrator
  Error: Out of memory.
         bad allocation
  StackTrace:
   - MgTileServiceHandler.ProcessOperation line 83 file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\tile\TileServiceHandler.cpp
   - MgOpGetTile.Execute line 150 file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\tile\OpGetTile.cpp
   - MgServerTileService.GetTile line 263 file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\tile\ServerTileService.cpp
   - MgByteSink::ToFile line 245 file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\common\foundation\Data/ByteSink.cpp
 Out of memory.
 bad allocation
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/520>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
