[mapguide-trac] #524: MG 2.0 BUG...after GetSelectionXML
MapGuide Open Source trac_mapguide at osgeo.org
Sun Mar 30 06:42:21 EDT 2008
   Reporter:  macieksk  |       Owner:
       Type:  defect    |      Status:  new
   Priority:  high      |   Milestone:  2.1
  Component:  General   |     Version:  2.0.0
   Severity:  major     |    Keywords:  getselection setselection
External_id:            |
 Hi
 when i use onclick event (when user click on map ex. polygon i create pop-
 up window whit all information about object - i get xml whit ID of this
 object from GetSelectionXML)
 ---- code whit GetSelectionXML script (javascript)
 params = new Array("xml",parent.ViewerFrame.mapFrame.GetSelectionXML()
 ,"SESSION",parent.ViewerFrame.mapFrame.GetSessionId(),"MAPNAME",encodeURIComponent(parent.ViewerFrame.mapFrame.GetMapName()));
 parent.ViewerFrame.formFrame.Submit("../my_folder/onselect.php", params,
 "scriptFrame");
 ----end code
 i select polygon in onselect.php file...
 after 1 or 2 click mgserver is down....and i get this error
 ---- error witch is send from my XP develop machine------
 szAppName : mgserver.exe     szAppVer : 2.0.0.2308     szModName :
 msvcr80.dll
 szModVer : 8.0.50727.1433     offset : 00008aa0
 ----- end error---------------------
 i use this code in version 1.1, 1.2 without any problem....
 i have this problme (mgserver.exe crash ) whit 2 method
 GetSelectionXML(), SetSelectionXML()
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/524>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
