[mapguide-trac] #539: Implement CLIENTIP and CLIENTAGENT tracking in the Server's Access.log
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 1 18:37:42 EDT 2008
 Reporter:  tonyfang  |         Owner:  tonyfang
     Type:  defect    |        Status:  closed
 Priority:  medium    |     Milestone:  2.1
Component:  Web API   |       Version:  2.0.0
 Severity:  minor     |    Resolution:  fixed
 Keywords:            |   External_id:
Comment (by jbirch):
 What is this being used for (other than logging)?
 If it's important to know the end user's IP address, then maybe it's
 worthwhile determining whether they're behind a proxy and recording the
 HTTP_CLIENT_IP or X_FORWARDED_FOR values.
 These can be problematic though; sometimes not containing a single IP,
 sometimes with junk embedded.  And they come from the client, so can't be
 trusted the same way as REMOTE_ADDR.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/539#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
