[mapguide-trac] #546: Deselect and tooltips very slow in MapGuide
MapGuide Open Source trac_mapguide at osgeo.org
Mon May 5 18:10:28 EDT 2008
   Reporter:  trevorwekel        |       Owner:  trevorwekel
       Type:  defect             |      Status:  new
   Priority:  high               |   Milestone:  2.1
  Component:  Rendering Service  |     Version:  2.0.0
   Severity:  critical           |    Keywords:
External_id:  1072510            |
 Create a map with a single vector layer in MapGuide from an Oracle
 database.  The database should contain more than 50,000 features.
 Select a feature.  Selection is highlighted in 1-2 seconds.  Deselect by
 hitting white space.  The MapGuide Server process pins the CPU for 15
 seconds or more depending on the dataset size and eventually deselects the
 feature.
 This will also occur during hovering if a tooltip is defined for the
 layer.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/546>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
