[mapguide-trac] #560: Consider adding a repository validator
MapGuide Open Source trac_mapguide at osgeo.org
Sun May 18 09:50:31 EDT 2008
   Reporter:  ksgeograf  |       Owner:  ksgeograf
       Type:  defect     |      Status:  new
   Priority:  medium     |   Milestone:
  Component:  Maestro    |     Version:
   Severity:  major      |    Keywords:
External_id:             |
 - Comments from the original bugreport:
 I keep running into problems because column names have changed since I
 created layers so the mappings are broken, data sources have moved, etc,
 etc.  It would be great if you could build a validator that checked to
 make sure that all references to other resources, columns, etc, were
 valid.
 Yes. That would be a good feature.
 It would make sense to run it before saving a resource, to alert the user
 of any
 mistakes.
 It would be a small addition to make it run on a folder or the entire
 repository.
 I know there are quite a few users out there who have run into trouble
 because of
 bad references or invalid attribute mappings that would love to see this.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/560>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
