[mapguide-trac] #579: add "load procedures"
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 29 14:25:55 EDT 2008
 Reporter:  andrewd  |         Owner:  ksgeograf
     Type:  defect   |        Status:  new
 Priority:  medium   |     Milestone:
Component:  Maestro  |       Version:  2.0.1
 Severity:  minor    |    Resolution:
 Keywords:           |   External_id:
Comment (by ksgeograf):
 As I understand, the "Load Procedures" are there to facilitate the usage
 of files in the Autodesk proprietary formats (DWG and friends) in an
 otherwise open source environment.
 I can see the use for SHP files, because they contain style information.
 However, I have to either find or build an SHP library that can extract
 the style information from SHP files. That is a rater large task, so I
 will not implement it right away, but keep it in mind.
 Do you know of other spatial formats that carry style data within the
 spatial datafile?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/579#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
