[mapguide-trac] #589: Maestro: Show dependencies
MapGuide Open Source trac_mapguide at osgeo.org
Sat May 31 12:55:47 EDT 2008
 Reporter:  jbirch       |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  assigned
 Priority:  low          |     Milestone:
Component:  Maestro      |       Version:
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Comment (by jbirch):
 Hmm.  Good question.
 An obvious one would be to navigate to the resources.  Or to select
 multiple resources and click on "Open".  Obviously couldn't do this as a
 treeview though :)  I'm surprised there isn't a decent multi-select
 treeview for .Net.
 Would it make sense to have this as a non-modal stay-on-top navigator
 window, so you could move it off to the side and work your way through the
 list fixing up references to point to different resources?
 There is potential for a "Replace With" function, but with the possibility
 of replacing with a resource that doesn't match this might not be worth
 implementing.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/589#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
