[mapguide-trac] #740: GETSPATIALCONTEXTS and GDAL Always Returns Default Extents
MapGuide Open Source trac_mapguide at osgeo.org
Mon Nov 3 03:56:50 EST 2008
 Reporter:  crispinatime     |         Owner:
     Type:  defect           |        Status:  new
 Priority:  medium           |     Milestone:  2.1
Component:  Feature Service  |       Version:  2.0.2
 Severity:  major            |    Resolution:
 Keywords:                   |   External_id:
Comment (by crispinatime):
 You say above,
 >> It reads all the coordinate systems reported by the FeatureSource,
 >> and then "overrides" them with the samme coordinate system.
 But as the TIF file has no CS it seems the FeatureSource is assigning a
 default one in the return values which then gets populated into the
 Maestro UI.
 But I think that the original point about GETSPATIALCONTEXTS not working
 when querying a GDAL FeatureSource with no CS (but valid bounds in a TFW
 file in my case) is correct!
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/740#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
