[mapguide-trac] #753: Thick horizontal / vertical lines near display edge are not correctly drawn using GD
MapGuide Open Source trac_mapguide at osgeo.org
Fri Nov 7 13:12:40 EST 2008
using GD
   Reporter:  waltweltonlair  |       Owner:  waltweltonlair
       Type:  defect          |      Status:  new
   Priority:  medium          |   Milestone:  2.1
  Component:  General         |     Version:  2.0.2
   Severity:  minor           |    Keywords:
External_id:                  |
 With GD renderer, any horizontal / vertical line located offscreen is not
 rendered.  This logic is incorrect in the case where the line has
 thickness.  If the line is offscreen, but close enough to the edge where
 its thickness overlaps the visible display area, then it needs to be
 drawn.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/753>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
