[mapguide-trac] #545: Categories.txt is in the wrong place
MapGuide Open Source trac_mapguide at osgeo.org
Mon Nov 10 12:00:31 EST 2008
 Reporter:  ksgeograf                                      |         Owner:  brucedechant
     Type:  defect                                         |        Status:  closed
 Priority:  medium                                         |     Milestone:  2.1
Component:  Server                                         |       Version:  2.0.0
 Severity:  major                                          |    Resolution:  wontfix
 Keywords:  categories.txt PROJ_LIB nad coordinate systrm  |   External_id:
Changes (by brucedechant):
  * status:  new => closed
  * resolution:  => wontfix
Old description:
> I have a Danish WinXP IIS .Net installation of MapGuideOS 2.0.
> The previous version was uninstalled before installing the current.
> Categories.txt is located in:
> {{{C:\Programmer\MapGuideOpenSource2.0\Server\Bin\}}}
> but the PROJ_LIB environment variable is set to:
> {{{C:\Programmer\MapGuideOpenSource2.0\Server\nad}}}
> This means that only the "Arbitrary XY" coordinate systems are avalible.
> There are other files in the "nad" folder.
> Copying the file into the expected location does not show the missing
> coordinate system categories.
New description:
Comment:
 The next release will be using CS-MAP instead of PROJ4. CS-MAP doesn't use
 the Categories.txt file and uses a different environment variable.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/545#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
