[mapguide-trac] #760: re-projected rasters have lines where the grid triangles meet
MapGuide Open Source trac_mapguide at osgeo.org
Wed Nov 12 17:07:55 EST 2008
   Reporter:  tonyfang           |       Owner:  tonyfang
       Type:  defect             |      Status:  new
   Priority:  low                |   Milestone:
  Component:  Rendering Service  |     Version:  2.0.1
   Severity:  minor              |    Keywords:
External_id:  1147564            |
 Using Studio...
 - Using Load Procedure: add a raster image, specify the appropriate
 coordinate system
 - add the resultant layer to a map
 - change the map's bg color to something that contrasts with the raster
 - change the map's coordinate system to something else (invoking raster
 re-projection)
 - preview the map
 --> notice there are faint lines where the grid triangles meet
 It is AGG’s anti-aliasing that is causing the grid-lines.
 When I change the calls from render_scanlines_aa (aa = anti-aliasing) to
 render_scanlines_bin, the grid lines disappear.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/760>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
