[mapguide-trac] #762: MgDisposableCollection class is not exposed in the web tier API
MapGuide Open Source trac_mapguide at osgeo.org
Fri Nov 14 16:21:17 EST 2008
 Reporter:  brucedechant  |         Owner:  brucedechant
     Type:  defect        |        Status:  assigned
 Priority:  low           |     Milestone:
Component:  Web API       |       Version:  2.0.1
 Severity:  minor         |    Resolution:
 Keywords:                |   External_id:
Old description:
> The MgDisposableCollection class is not exposed in the web tier API and
> it should be because the coordinate system API returns this object from
> the MgCoordinateSystemCatalog GetGeodeticTransformations() API.
New description:
 The !MgDisposableCollection class is not exposed in the web tier API and
 the !MgCoordinateSystemCatalog !GetGeodeticTransformations() API.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/762#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
