[mapguide-trac] #763: Add CSMap to the OEM solution file
MapGuide Open Source trac_mapguide at osgeo.org
Mon Nov 17 19:02:35 EST 2008
   Reporter:  jbirch        |       Owner:
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  2.1
  Component:  Build System  |     Version:
   Severity:  major         |    Keywords:
External_id:                |
 Currently, when building MapGuide, CSMap needs to be compiled
 individually.  This should be added to the OEM.sln file.
 As well, Hugues added:
 If you add CSMap to Oem.sln you might be interested in the post
 build steps located in the CSMap solution.  That solution builds
 the dictionary compiler and then builds the dictionaries
 automatically.
 Building the dictionaries is done automatically in release mode
 only to speed up the time in debug environments, since the source
 dictionaries are not updated very often.
 So, if that post build step is added, that also means the
 dictionary compiler would need to be added to oem.sln
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/763>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
