[mapguide-trac] #766: Re-projected raster does not look good in Fusion Overview Map (and really small windows)
MapGuide Open Source trac_mapguide at osgeo.org
Tue Nov 18 17:25:30 EST 2008
small windows)
   Reporter:  tonyfang           |       Owner:  tonyfang
       Type:  defect             |      Status:  new
   Priority:  medium             |   Milestone:
  Component:  Rendering Service  |     Version:  2.0.1
   Severity:  minor              |    Keywords:
External_id:  1159529            |
 From Addendum 3 in MapGuide RFC 51 - Raster Re-projection
 http://trac.osgeo.org/mapguide/wiki/MapGuideRfc51
 If the RasterGridSize is close in size to the actual width or height of
 your image (e.g. a RasterGridSize that is ~50% of the height/width), and
 the raster re-projection is more than a simple affine transformation (e.g.
 LL84 -> World-Sinusoidal), then you will end up with a poor raster re-
 projection.
 One place you will commonly encounter this situation is with the Fusion
 Overview Map. This may also occur when your window size is very small.
 To address this, a few more configuration settings will be added to the
 serverconfig.ini. In addition to RasterGridSize, we will also add
 MinRasterGridSize and RasterGridSizeOverrideRatio.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/766>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
