[mapguide-trac] #773: Composite line styles don’t connect cleanly leaving a “black” join mark
MapGuide Open Source trac_mapguide at osgeo.org
Wed Nov 19 19:16:37 EST 2008
   Reporter:  zspitzer  |       Owner:
       Type:  defect    |      Status:  new
   Priority:  low       |   Milestone:
  Component:  General   |     Version:  2.0.2
   Severity:  trivial   |    Keywords:
External_id:            |
 When using composite lines the join at the node points do not render
 cleanly leaving a black join mark which is the lowest colour in the
 composite line.
 Maybe the line joins need to be set as ”round caps” rather than “square
 butt caps” for any additional line style set as a composite line.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/773>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
