[mapguide-trac] #719: Compile : DWFTK will not build on ubuntu
MapGuide Open Source trac_mapguide at osgeo.org
Thu Nov 20 19:48:22 EST 2008
 Reporter:  mwtoews       |         Owner:
     Type:  defect        |        Status:  new
 Priority:  medium        |     Milestone:
Component:  Build System  |       Version:  2.0.2
 Severity:  major         |    Resolution:
 Keywords:                |   External_id:
Comment (by tomfukushima):
 The error seems to point to an error in the way the dwf_max is defined.
 Search for #define dwf_max and have a look at it; it seems that there is a
 syntax error there.  If you post the code for dwf_max here; someone may be
 able to spot the problem.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/719#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
