[mapguide-trac] #726: MapGuide Stops Listening on 2811 (Client Connections)
MapGuide Open Source trac_mapguide at osgeo.org
Sun Nov 23 00:30:02 EST 2008
 Reporter:  rbranson  |         Owner:
     Type:  defect    |        Status:  new
 Priority:  high      |     Milestone:
Component:  Server    |       Version:  2.0.2
 Severity:  critical  |    Resolution:
 Keywords:            |   External_id:
Comment (by amitmarty):
 We have nailed it down to the tile service.
 We have a base layer which is from a dwf file.
 When this layer is on there are a large number of connections generated to
 port 2811.
 After the number of ESTABLISHED connections go over 55, No more
 connections are allowed to this port till the mapguide server is
 restarted.
 If we remove the base map from the application the number of ports being
 used drops dramatically and pushing the server only takes it to about 35
 connections on port 2811.
 The base layer is very important for us to give context to the feature
 objects.
 We would appreciate any feedback.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/726#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
