Re: [mapguide-trac] #773: Composite line styles don’t connect cleanly leaving a “black” join mark
MapGuide Open Source trac_mapguide at osgeo.org
Mon Nov 24 02:37:49 EST 2008
 Reporter:  zspitzer           |         Owner:
     Type:  defect             |        Status:  new
 Priority:  medium             |     Milestone:
Component:  Rendering Service  |       Version:  2.0.2
 Severity:  major              |    Resolution:
 Keywords:                     |   External_id:
Comment (by waltweltonlair):
 I noticed the same problem while looking at the data attached to ticket
 732.  For that data set, the problem is that the layer definitions have
 empty PointTypeStyle and AreaTypeStyle elements (in addition to the
 LineTypeStyle).  This interferes with the code which checks if we should
 display a composite line style.  The check fails, and so the code ends up
 treating the LineTypeStyle as a non-composite.
 A quick workaround is to remove the empty PointTypeStyle and AreaTypeStyle
 elements from your layer definition XML.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/773#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
