[mapguide-trac] #462: Server Crash and Unresponsive using OSGeo.Gdal FDO provider
MapGuide Open Source trac_mapguide at osgeo.org
Tue Nov 25 19:40:17 EST 2008
 Reporter:  zspitzer  |         Owner:
     Type:  defect    |        Status:  reopened
 Priority:  medium    |     Milestone:  2.0
Component:  General   |       Version:  2.0.2
 Severity:  blocker   |    Resolution:
 Keywords:            |   External_id:
Comment (by tomfukushima):
 Thanks Zac, I couldn't reproduce this using IE, but once I moved to using
 Google Chrome, a problem showed up right away.  I only needed to do a
 single zoom and then pan.  Steve, this is pretty easy to reproduce.  Come
 see me if you want to see it.  The server continues to work though, as I
 can continue to get in through Studio; it seems that the GDAL provider is
 hooped because I can't do anything with raster.
 This is the error that I get:
 <2008-11-25T17:34:24>   Ajax Viewer     144.111.170.90  Anonymous
  Error: Failed to stylize layer: TrueMarble.8km.5400x2700 layer
         An unclassified exception occurred.
  StackTrace:
   - MgMappingUtil.StylizeLayers line 786 file
 d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\mapping\MappingUtil.cpp
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/462#comment:14>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
